decellerating problems
blueta
I just got my 84 today and when I drive it around (doesn't matter hot or cold) and slow down it doesn't want to downshift gears. For instance, if I'm in second gear and I start to slow down the car starts to idle really rough. The slower I go the worse it gets. To the point where it shakes like a manual trans and the brakes even freeze up like it's on the verge of stalling. Someone please give me a heads up on what's going on. Thanks
Jim
sounds like the clutch aint unlocking .need more info to elaborate on the brakes though .is this a transplanted motor in a car w/vaccum assisted power brakes ?is the tcc wired thry the brake switch ?whats it do if you shift to revers or neutral when it misbehaves?www.ckperformance.com
