Feb 15, 2011 #1 F fmster Member Joined Dec 18, 2008 Messages 287 Hi to all! How far down in the hole doe's the piston sit from the deck on a stock 86 block? What is CR? Thanks.
Feb 15, 2011 #2 T Turbo-Archie Active Member Joined Oct 8, 2002 Messages 1,529 There is a ton of info on this if you do a search... I think the CR is from the CL of the pin to the top of the piston.. ..
Feb 15, 2011 #3 B Blazer406 Mechanical Engineer Joined May 2, 2002 Messages 5,068 Turbo-Archie said: There is a ton of info on this if you do a search... I think the CR is from the CL of the pin to the top of the piston.. .. Click to expand... Compression Ratio? I think you are describing Compression Height?
Feb 15, 2011 #4 T Turbo-Archie Active Member Joined Oct 8, 2002 Messages 1,529 Yep, I over looked it and thought it was a more common asked question.. also, are you asking what *the* CR is? ..
