I've been trying to tweak my car and one of the troubles I've been having is ridiculous gas consumption....like 13-15mpg
I've posted a couple times but I didn't have my scanner working...'till now..
I did some readings with the car in closed loop and cruising:
MPH: 54-55
RPM: 1675-1700
CLT: 163*
INT: 123-135
O2V: frequent peaks in the mid-700s
MAF: 15-17 (LS1 Maf with translator)
BLM: pegged at 145-146
O2X#: fluctuated between 7-25
MATF: 66*
BATT: 13.8vdc
EGR%: 21-27
IAC: 25
Then, several minutes later, I did a 0-WOT(77mph) blast, building about 5psi on the line and then punching it:
from 2600-4000rpm my INT was steady at 128
My O2V varied slightly between 824 (3800rpm) - 882 (4050rpm)
MAF: 241 @ 4100 (peak recorded rpm during run)
BLM pegged from 0-77mph at 147
MATF: 72-68
EGR%: 0
IAC: 61 for entire run
Knock RTD: 0 throughout run
I'm running 42psi static on blue tops with a Testa chip. Fuel filter was recently replaced, oil was just changed yesterday, all vacuum lines have been replaced.
Any analysis, ideas or "stuff"? Thanks.
MPH: 54-55
RPM: 1675-1700
CLT: 163*
INT: 123-135
MATF: 66*
BATT: 13.8vdc
EGR%: 21-27
IAC: 25
MATF: 72-68
EGR%: 0
