Deep scratch on steering column
  • Thread starter Thread starter yosshimura
  • Start date Start date
Y
yosshimura
Guest
I used noticed that their is a scratch on the top of my steering column about an inch long...width? about as wide as a small paper clip tip (make sense? :confused: )...
It was caused by that dumb collar you put around the steering column for theft prevention :mad: . Guess the weight, the heat.. .....:rolleyes:
So, now I want to fill it, sand it, and touch it up with the matching interior paint. I got the paint, but am unsure what to use for filler. :( Any ideas?
I am thinking of that filler that is used on the body to fill hair lines in the primer prior to painting, but not sure ....
http://temp.corvetteforum.net/c4/yosshimura/
I have the same problem! Where did you find the paint? Is it spray can or touch-up bottle? Paul.
Kirban. It is spray paint, but I will just be dabbing it with a small piece of clothe or somethin...no spraying... They do sell it to brush on, I am told.
I fixed my scratch this wknd with some putty used to fill in scratchs in primer when you are painting cars. Letting it dry all week, will sand it a bit next wknd, and paint. We'll see how it turns out.
How did it turn out?
Are there additional sources for the interior gray paint?
At the parts stores they have these little plastic paint brushes with a little ball of brushes at the tip. It would make following the scratch easier. Like doing a scratch on the body. Get some super fine (1500 grit) sandpaper and lightly sand in the new paint. Put a dab of compound on a rag and go to work. Follow with some polish.
