Heres the skinny, I just went through my 86 GN. New head gaskets, cam, t49 turbo, 009 injectors, ultra chip w/thumbwheel. fuel pump, etc, etc,I got the cam from Postons, a 107 with 202/202 duration 269 lift. I was advised not to install a double roller, cuz they can hit cover and cause spark retard, so,,, I put a all steel stocker in only goes on 1 way, 1 keyway. The car idles kinda rough, and I dont think she spools up fast enough, not much power on the low end. my question is, should I have degreed the cam instead of putting it in at 0 tdc? I'm looking at the spec sheet, and it says all specs are given at 4 adv. Could putting it in stock position cause the rough idle and less than great power on low end? Builds tons of boost at around 2800, but below that kinda doggy. Anyone put this cam in their car, better results? I still have the stock convertor and rear end gears. Thanks, Ken, Buffalo NY.
