DENSO or BOSCH Fuel Pumps...
Royal-T-Ltd
Wanting to stay internal... narrowed it down between Denso "Supra" pump p/n 950-0155 and possibly the Bosch 044 [i think thats the P/N] and just wanted to get input on these pumps OR similar and double check that these ARE the correct part numbers.....
i am still on the PowerTour but wanted to order soon and replace when i get home. thanx
I don't think the Bosch 044 will fit with the sock, but sockless is possible.
The Supra not only fits with a few minor mods ( cutting the float arm nub and a small part of the bottom bracket for the sock to fit ) but Racetronix has an upgraded wiring harness to increase voltage by 5% making it even stronger.
Yes, you have the correct # for the kit (incl. pump, strainer, o-ring, hose, clamp...)
I'd go to sparkplugs.com for purchase (get you a Denso O2 sensor while you're there & spread shipping cost...)...
