deseil turbos
madhat
what is the difference between the turbos we use and the turbos used on turbo deseils? why does no one ever use deseil turbos on our cars?
I'm thinking about a holset HY-35W for my own setup. Some probs are the flanges, and that the A/R of a lot of Diesel turbos tend to be in the low 1.X areas, most people use about a .86 AR or less. The turbo mentioned above is off of a Cummins turbo diesel, I've had a guy with a Syclone say he expected about 400-450 RWHP out of it. Then again he also had an extra 31 cubes to play with. I'm tempted to use it, but I wouldn't be surprised if I need a *lot* of stall. The HY-35W mentioned above usually sells for about $300 for a low milage pull, has an internal wastgate with a HUGE puck and these like high pressure ratios by design. The powerstroke tubos are another turbo, but I wouldn't even think about one unless you're doing an all out drag car and probably only then with a 4.1L. You're talking about an 8X mm wheel and a 1.1X AR. It also has an internal gate. I wouldn't use either without the aid of head work, camming, stall and a good down pipe/output exhaust.
So they are just too big for the average turbo regalist, but if you were to use a big block or something you would have a pretty good turbo on your hands? I once heard that deseil turbos basically run out of gas early and that why they arent used for racing...I didnt really understand how that could be, but I guess it's not true.
thanks,
wesley
thanks,
wesley
remember the operating range of a dezzel.... not much more than 4000rpm give or take,and my 7.3 powerstroke rarely see's that
i remember reading somewhere that the turbo off an old powerstroke was the same as a te-60, only a slightly bigger hot side, and 4 bolt. I'd really like to try to get ahold of one, i'm sure the money would be reasonable at a junk yard, and if i could find the powerstroke intercooler at the same time, that would work out pretty good.
i'm thinking you would need a lot of head work and stall to make it work.
