I'm thinking about a holset HY-35W for my own setup. Some probs are the flanges, and that the A/R of a lot of Diesel turbos tend to be in the low 1.X areas, most people use about a .86 AR or less. The turbo mentioned above is off of a Cummins turbo diesel, I've had a guy with a Syclone say he expected about 400-450 RWHP out of it. Then again he also had an extra 31 cubes to play with. I'm tempted to use it, but I wouldn't be surprised if I need a *lot* of stall. The HY-35W mentioned above usually sells for about $300 for a low milage pull, has an internal wastgate with a HUGE puck and these like high pressure ratios by design. The powerstroke tubos are another turbo, but I wouldn't even think about one unless you're doing an all out drag car and probably only then with a 4.1L. You're talking about an 8X mm wheel and a 1.1X AR. It also has an internal gate. I wouldn't use either without the aid of head work, camming, stall and a good down pipe/output exhaust.
