Anybody know anything about this product? Or better yet anyone using it? Before anyone says what I should use, Im just asking about this one. I know what everyone will recommend, and no disrespect but Im curious to this brand.
Never used it, but if you look at all the questions people have about there kits there is normally One guy who helps them troubleshoot the problem, and has a good reputation
I had a Devil's Own kit on my WE4 for a while. I went 10.78 with the kit and 93 octane with a pretty mild set up. I later swapped the car to a Alky Control kit and the car went 10.76. The kit works very well and I never had any issues with it. The best thing the Alky Control kit has going for it is when you combine it with the Turbo Tweek alky chip you pretty much have a plug and play set up with little or no tuning required. With the DO kit I had to do a little tuning to get things exactly right--nothing major--just some minor tweakin in the TT chip to get the fuel exactly right. I told Eric at TT what size nozzles I was running and what PSI the kit was putting out and he did an amazing job of setting up the chip and got it 95% of the way there, I just had to help the last 5%.
i ran one on mine before i swapped to race gas. my only complaint is that it uses plastic lines that will melt if the get close to a hot valve cover and the alky will ignite lol. other than that it was an easy system to use. i did go back with some wire loom to protect the lines and never had another issue.
