B
Butch
Guest
Guys, I have transplanted an LT1 from a corvette into my Full Size Blazer and I have a few issues that I could use some help with.
I also have a WE4 and have learned almost everything I know from this board!
The Engine is stock with a ZZ9 cam (not sure of specs, I will find them and post) and nice PnP LT1 heads with big valves and roller rockers, electric Water pump, long tube headers with duals, no cats right now.
The DFI and FastTrack harness was installed by very reputable shop and tuned with me riding in the truck, but...
It is being run closed loop with a heated NON Wideband O2 sensor. Unless I am missing something the system is constantly correcting to 14.7/1 AFR. I dont think you can set a target AFR with this system. It is a BtB system. Well it pretty much runs like crap, just doesnt have much power until like 3000 RPM's. It doesn't backfire or anything like that and it idles fine at 750 RPM's with about 18" of vaccum.
My thinking is that maybe I should be running it open loop, I mean what good are non Wideband O2 sensors right?
The other problem is that I think this cam might be ok for a car but this is a very heavy 4 wheel drive vehicle, heavier than a Caprice even. What is the cam theory for building power at lower RPM's? I mean this thing go's 70 MPH at like 17-1800 RPM's, If I try to accelerate it's a dog unless it downshifts. About the only time it seems to pull hard is above 2000 RPM's.
Sorry so long but I want to try to fully describe my problem.
Thanks in advance for any suggestions.
Butch
PS. Can I upgrade this sytem to Wideband? Would it be worth it?
Butch
