ChrisCairns
Senior Member
- May 24, 2001
I have a no spark intermittent problem
Car is now full S2 with FAST.
It first manifested itself at Woodburn, Oregon last year. The engine simply stopped on return road. I had it towed back to the pit and changed to a spare coil pak/module WITHOUT the Buick adapter for the MSD ignition box. It started right up.
I then returned the MSD box and they shipped me a new one, admitting they had found a problem. I had no more engine suddenly stopping. I went to Vegas....never had that problem. I then put the MSD box and adapter back in. Started fine until I removed the engine for a refresh.
I got the engine back and I put it in. It wouldn't start. I checked lots of stuff and it finally started .... after I found the plug which you insert into the adapter to isolate the MSD box was not plugged in all the way. I thought I had found the problem AGAIN.
Then it stopped suddenly a few days later. I switched out the coil pak/module and put another one in without the adapter and it started. It ran right up to last Saturday at the track without the MSD box and Adapter where after the 3rd pass it stopped again on return road. And all three passes had been horrible with outrageous missing. I put in a new crank sensor once home...still no spark.
Yesterday I found the cam sensor reluctor was loose. Lil screw had backed out. Tightened it up and the engine started immediatedly and ran "right".
Today some friends came over and I started it up for them, after running it earlier for 20 minutes.... and within 3 minutes, after idling and reving up perfectly, it stopped. Won't restart. No spark.
I've checked many connections, including to the FAST box, to the old ECM connectors, coil connector, crank sensor connector, cam sensor connector and ran my finger over many more wires and connectors. Nada.
I need to find this problem before the Woodburn Buick meet in two weeks. We don't have a lot of Buick stuff out West here so this meet will be cool IF I can find the gremlin.
All suggestions are very welcome.
Thanks, Chris
Thanks, Chris
