difference between regular 200 4R and GN 200 4R
  • Thread starter Thread starter FinGN
  • Start date Start date
F
FinGN
Guest
Can anyone tell be if there's a difference in TCC lock up solenoid and the governer spring (which usually pops out) between regular 200 4 R and a BRF tranny from a GN? I think my BRF tranny needs both parts and I don't have a clue if these parts are the same in both trannys..
The solenoid itself is the same. The only difference will be that the solenoid harness on the BRF has four wires vs. three. You can easily transfer the fourth wire from the BRF harness to another if desired.
The governor spring is specific to the BRF calibration. TCI carries these as part #382205 if you need one.
