Sure you can put it on and run stock boost with a good chip and fuel.
You probably will see a ****ping 10-15 HP increase there too, and you probably couldn't tell the difference at the same pump gas boost levels, excepting for the increased lag with the TA60 you probably will feel that.
Bigger turbos need high boost to shine over the stocker, probably over 20 before the bigger TA60 will really outdo the stocker so you can feel it on the butt dyno.
Your scantool(s) should tell you when you get lean.
