I have an 85 T-TYPE W/ 87 drivetrain,has been a nightmare since I bought it! I had an ATR ext. wastegate stick and overboost causing blown head gasket.I had #3 inj. short on EGR causing another blown head gasket! The car has a Tial ext. wastegate,42# injectors, red"s XP pump,Te-44 turbo, PTE roller cam 210, heads & intake ported,kenne bell adj.FP. regulator, and a MAF Translator w/ an LS1 Maf.Now to the problem I'm having! Not all the time, but sometimes when I stab it to the floor, it start to take off real hard the I hear a pop out of it and it's like someone shut it off! I let off and then hit it again and it's ready to go!When this happens I go to my Direct Scan and at that point it shows all #s 0, and coolant -40!Also I have a turbo Tweak street chip in and Wot Fuel Setting that was at 140BLM's was now back to 128!It's like the computer was unplugged then plugged rigt back in!Also to get O2 Millivolts in 770 range,I have Trans. set at #2 set @wot,turbo tweak chip wot fuel @140 BLM's setting, and FP. set @ 52 Psi w/ Vac line off, running 19#'s boost! Hopefully someone out ther can help Please!
TIA,
ED Vitai
TIA,
ED Vitai
