so im on budget on my t-type and well im planning on gettting my hands on a old school direct scan question is i read that its for 86-87 years i have a 85 will i be able to run direct scan on it
No. Right from his website: DirectScan is the premier scan tool for 1986-1987 Buick Turbo Regals. Engineered specifically for these vehicles and others utilizing the '86-'87 Turbo Regal ECM and drive train
Yes, assuming you do the other sensors too. I can probably donate my Direct Scan to your cause if you like. You also need a laptop that can boot into DOS, like Windows 98.
Yes to the above. In addition to finding a laptop NO NEWER than WIN98SE, the laptop also needs to have a parallel printer port, which is what Direct Scan plugs into.
Have a complete Direct Scan. Make me an offer. Also have a complete SMC alky dual nozzle setup, Needs a new pump and the low alky float tinkered with. Pkg deal real cheap.
I would say Direct Scan will do just about anything Powerlogger will do unless you are a SERIOUS racer but then you would be using a FAST system. I would still use it instead of powerlogger IF I still had an older laptop. It will not run on Windows editions past I believe XP. You do NOT have to have a wideband. It is great but basically won't run on my new laptop. I have the original box, instructions, cables and a chip for 55 lb injectors. CHEAP.
