Is there any update for the Directscan that has some type of boost interface? I need to work on boost control problems and some sort of playback would be cool.
Originally posted by pwrhws Is there any update for the Directscan that has some type of boost interface? I need to work on boost control problems and some sort of playback would be cool.
If you get the turbolink boost harness, and use the 1.51 version of DS, you can replay boost using the IAT as an input. It's an odd interface since ou'll be reading degrees instead of PSI, but it can show you what's going on.
