Directscan connector
xrunner123
I lost my manual on the directscan and need to know which side does pin1 go.
If I am looking down at the ECM with the connectors at the top and the chip compartment facing me at the bottom, where is pin 1? Left side or right side?
I assume it's on the left, so I can run the ribbon up the back, correct?
Looking down at the ecm, with the "chip door" up, pin 1 goes to the right (Between the wide segment of board and the thinner segment.
I think they have an on-line instruction manual: www.chuengineering.com
the red stripe goes toward the gap in the bottom of the circuit board. if you hook it up backwards it is bad, bad. i fried the direct scan, my ignition module and ecm when my buddy hooked it up backwards
