Distributor vs S Hose suggestions
fxdxlr8
I dropped in the distibutor today,,, only after removing a temperature sensor and the fitting for the S hose. I don't see any way to run the S hose to its present location. What are those running distributors doing? In the last pic (by the C in CRH) you can see a capped off fitting. Could I run a hose to that fitting. I believe the S hose is just a bypass for when the thermostat is closed. How about if I just drilled a small whole in the thermostat and did away with the S hose. Thank-you in advance for any help or advice.
Ive been running without it for a couple years. I did drill two small holes in the thermostat perimeter.
No, Unless you invent the the super small super lowprofile distributor for our engines, THEN I will buy one too.
I don't run the "S" hose on my Blowthru
I did what Scott ATK did to the thermostat.
