Red Regal T
Senior Member
- May 24, 2001
Hey, one of our members, Steve Monroe, has a site that gives easy, complete, instructions on "how to" make up and install an alchohol injection system. I put mine together about three years ago. While you have to get parts from different vendors, it takes no more time to install than anything else. Cost me about $150 then and I think I can duplicate it today for $175. Spend more if you want. Here's Steve Monroe's website....
http://home.att.net/~stevemon/AlcoholInjMod.html
I have more than 60,000 miles on my car since I installed the diy kit, and can truthfully say, it has never failed to come on. I have no knock in high gear at 24 psi running a TE44 turbo. I never had any problem tuning it. Just figure your turn-on point, usually between 10 and 15#s of boost, set it and forget it. There is no pump speed to set. Pump is preset to 60 psi and I use a .032 jet and a one gallon reservoir. End of story! When people talk about alky being hard to tune, I really don't know what they're talking about.
Also, I've never used any type of lube in my reservoir. If it makes you feel better to use it, then use it. Maybe it's necessary if you only use your car as a weekend warrior. I use mine, all the time. Thanks again to Steve Monroe for making this alcohol kit recipe available for all Turbo Regal owners.
