Has anyone built a DIY wide band box & had success getting it to run properly? Also does anyone know if the diy-wb is compatible/can be made compatible to the Bosch wide band o2? Thanks Wayne
I've built over a dozen of them. Other then an error on my part with the first 2 never a problem.
No, you have to use the Honda/NTK type sensor with it.
If you want one of the early non-masked PCBs email me. Your's for postage.
