I have a stage II off center that pump is going on. Motor is pretty much together besides oil pan. The fitting for the discharge of pump is a number 10. Thought about going into block where turbo feed line was but it is only a 1/4 pipe thread. Will this restrict it to much? To drill out this hole and retapp I will need to disassemble. I also have a 3/8 pipe thread hole in the back of the block. Is there any reason not to use this hole other than line getting close to headers.
Thanks Michael
Thanks Michael
