Had to replace my puny 14" long cone filter so I decided to step up the airflow.
Thats a 12 inch long by 7.5 inch diameter cylinder. The opening is 6 inches. I got the idea to do this after seeing this
for sale online. Its a velocity stack that is designed to mount to a 3" pipe and the stack has a 6" outer diameter.
Using that velocity stack gains almost 100 cfm over an open pipe @ 10"h20. I believe a 6 inch long pipe will flow 390 cfm without that, and then will flow like 480 cfm with it.
You'd also be surprised what effect tube length has on airflow. The airflow quickly reduces the longer the pipe is. Turbos don't like to suck air, they are not efficient at it.
anyway, thought youd get a kick out of it. I'm still chuckling every time I look at it thinking what people are going to say when I go to the track.
