Do I need these lines
wb's87
willrock
I removed the EGR. I'm not sure which vacuum lines I need to keep. Also the EGR looks like it was leaking. There is a small amount of oil blowing past the gasket. Is this normal or an indication of something else?
TIA
Just remove the vacuum t and line going to the egr
The rear filter is for your
ac-heat controls
Ok. So I should end up with a vac line from the steel line from the vacuum block, the inline filter out to the three way for the ac/heater line. Correct?
I bought a EGR block off plate which uses a bolt to attach it. How do you get the original stud out of the manifold? I didn't want to break it off.
Yes. And u double nut it to get it out. Or a small pair of vice grips . remember on aluminum always tighten it till it moves first. Then loosen.
The base of the stud just before the manifold should be void of threads. That's where you grab on with the small visegrips
