quickbrick
- Oct 13, 2001
i had a bov on my car and it was stayed at 128 at idle, but when you give it light throttle at low rpms it falls to 105 then jumps to 115. when i let go of the throttle it goes back to 128 and stays. full throttle stayed at 128. I thought it was the bov opening up at low rpm causing this. so i swapped the uppipe w/the stock one.
w/o the bov its 128 at idle. still goes down to 105 at light throttle.if i give it medium throttle it goes to about 135 and full throttle is 128. cruising at 60 it stays at 129.
is it normal for it to go to 105 at low rpm low throt? o2s are anywhere from 80-800 at low cruise. cc climb fine at cruise but stop at idle sometimes. i guess the bov wasnt causing it so i might put it back on. im just learnin how to tune now, i just got my scanmaster acouple days ago. thanks for the help.
