groumoutis
- May 1, 2009
I like the way they look and the sequential effect but I don't want to ruin the factory wiring. So if anyone can give me their opinions of them I would appreciate it.
SignUp Now!You do splice them in the trunk right on the left side inner trunk area at the factory harness connector. The factory bulbs not being used where the LED boards plug in are simply removed and packed with grease and taped over real well so they can be converted back to stock in the future.. This leaves No Splices what so ever in the factory harness outside of the trunk!Ok. I read the installation manual on your website and I must have misunderstood about the splicing of the wires.
You certainly will now! I refunded you the 10%Scot, I just ordered a set and didn't get the 10% off.
The manufacture didn't use them in the very first design because those plug in adapters were found to be unreliable so they never used them. They went on to say that those plug in adapters failed to make a good proper connection like some bulbs do when plugging them in and that LED's are very sensitive to voltage which is why they recommend the solid connection in the trunk...But hey if they work, they work! right?Here's the adapters I used. Check with volt meter. IIRC white is ground on these
(2) 1157 Wire Plug Adapters For Tail Lamp Sockets / Covert Wiring To 1157 Socket by Generic http://www.amazon.com/dp/B007FUF32S/ref=cm_sw_r_udp_awd_5MJWsb1NBCFE8
On the GNS websight...there is a video.Got any pics of them in action?
Found it. Very nice. Putting this in my file for next years body and paint upgrades.On the GNS websight...there is a video.
