The Power Plate from RJC should come with the gaskets, unless you picked up a used one maybe.
I'm using the power plate on both my cars with provided gaskets. The WE4 only sees 15psi, but the 86 sees 32psi, maybe more in good air.
Zero issues with either car and those gaskets.
I have although considered adding an O-ring channels on both the intake and upper plenum surface allowing me to remove the gaskets. I would consider this on a new build, but not worth my time to fix a problem that doesn't exist.
My only gripe about RTV is the mess it makes and cleanup and prep required if I have to work on it in the future. Not to mention if prepped properly, the RTV will make separating the upper plenum very difficult.
