TURBOPOWERED68
David
- Jan 31, 2006
the engine has about 180K miles
the last time on the road it spun the #6 rod bearing.
The plan is to ONLY
1-Hone the block
2-cut the crank to what ever it needs
3-clean and re-ring the OE pistons
4-Re-size the rods
5-clean and re-use the OE timing cover
6-stock rebuild on the heads
7-roller cam with GM lifters and the spider hold down
Yes every thing will be cleaned and looked over and only damaged parts will be replaced.
then beat the crap out of it is it lasts long enough.
The plan is to ONLY
1-Hone the block
4-Re-size the rods
