Dominator vs Fast vs GNECU
yarbeau
Darth Vader
I've been scouring the net to find a breakdown of pros/cons of each system. Hoping someone can point me in the direction or even break it down. Not building a racecar just want the safety and reliability of a new ECU. A little background on the car.
Stock 87 GN. Wiring harness seems to be in rougher shape so I may be looking at replacing it entirely with the new ECU. New dash system would be a nice add on as I am not a fan of gauge pods littered around the interior. Goals are reliable 9-10 second street car on pump gas and meth that i can hop in and never worry how its going to react. $$$ is of course a factor, i know nothing is cheap but if one system is 2k more but offers the value I'm only doing this once. I am not a tuner so the less I have to tinker with on a computer the better.
Pulling the motor this week to send in to have it machined and long block assembled. This isnt going to be a quick turn around I am in no rush just want to make the best choice.
That factor is the main one.
These computer systems are alot and depending on how many sensors and what you wish to look at costs will jump alot.
The systems are only as good as the tuner period.
All of them including a stock ecm are fast enough to reach your speed goals.
It's how much you have to spend and who tunes and supports the computer setup
If:
a) you don't have some one to tune and you don't want to do it yourself
b) money is an issue
c) running gas and meth (not e85)
Get a new stock harness from Caspers Electronics and an appropriate chip from TurboTweak and be done with it.
I have had an ECUGN and currently run a Holley Dominator with a 12.3" pro dash. I love the Holley system and the dash lets me not have any other gauge pods and clutter which really cleans up the interior.
The ECUGN is more than capable but for me the software leaves a bit to be desired. In my opinion the Holley software is easier to use but you have to build some of the safeties that are already in the ECUGN yourself (more tinkering). If you want to use
Cost wise it is not cheap either way (prices are approximate and probably have gone up).
TurboTweak chip $125
Caspers Harness $1250
ECUGN $2100
DD-EFI Dash $700
Caspers Harness w/ECUGN addons $1400
If you want coil-near-plug add $325 + the cost of coils
Holley HP Kit (from Cruz; includes harness, coils, etc) $3500
Holley 12.3 Pro Dash $2000
3d printed dash/bezel/wiring $600
Prices just go up from there. I went with the Dominator over the HP due to wanting the trans controller and not being limited to 4 input/4 output. The ECUGN has more I/O than the HP but less than the Dominator.
If:
ECUGN $2100
DD-EFI Dash $700
Thanks so much for the breakdown. My hands were leaning to the Ecugn simply because of cost and this not being a race car/needing traction control/transmission access.
What was so negative about the ecugn that’s caused you to switch to Holley? In my situation I wouldn’t be looking at playing with the software and would leave it how TT sets it up for me. Is that reasonable?
Cheers!
