Done a little work, Whatcha Think?
Preluder77
OK Finally had sometime to work on the GN. Here are the mods i have done so far.
Walbro Pump
Hotwirekit
adjustable fuel reguletor
K&N Air Filter
Turbo Tweak Chip
86-87 computer
Right now i just have it set at 12psi boost and 44 psi fuel pressure. These Sound Right?
Also what should be my next step or mod? I got the money so tell me what to buy lol.
Im heading to the track this weekend what kind of 1/4 mile times should i see on stock tires with this setup?
youve got a scanmaster? if not get one so you can see how much boost you can get safelly.track usually have some good race gas,and you can turn up boost.....
get an adjustabe waste gate too:biggrin:
once tuned in,you should be able to get 15 psi with good 93 octane gas;)
Get a scanmaster and a knock gauge before you ever put an adjustable waste gate actuator. Get the car tuned first before you touch the waste gate actuator. A boost gauge measures knock signal to the ECM. The knock gauge on the scanmaster measures the ECM's response to the knock signal. Remember- The boost gauge and tach in the dash are useless decorations. I can help you tune your car- it is actually simple. Good luck- Brad
