door hinge pins
3.8Illusion
boost junkie
just went to GM first place i thought to look the upper hinges are 103 bucks a piece!!!! and the lowers were 70 i think. then i asked for a pin kit. He said they dont make a pin kit. Does anyone know of a aftermarket pin kit who carries it and roughly how much? thanks Steve
I think Autozone has them. I think I saw them there. Good luck.
HTH
Joel
Most parts stores have them in the help section. About the price of a big mac and fries.
Pins and bushings are available from GM. Part numbers are pins-#20046147 and bushings are #9721917. If the bushing holes are elongated or you already have an oversized bushing in there use #20429500. On the elongated holes the maximum that you can overbore the hole is 13mm. Its very important that the holes are centered too. Prolonged use of worn out hinges will cause your b-pillar to crack causing bigger headaches down the road.
