Door strikers
Bobs rare 6
Does anyone know which door striker our regals take? I am wanting to get the ones with the plastic insert to get rid of door clunking over bumps. Thanhs, Bob.
Those should be the smaller of the two. GM only uses two common sizes. The really huge one is early truck only. The smaller one fits everything else. The ones with the plastic sleeve should be hanging on the HELP rack. Replacements from GM are solid and don't have the sleeve. And the sleeve was metal and not plastic. If you suspect the rattle is coming from there than you may want to check the door latch too.
