Door swap questions
DKREDT
I am currently restoring my 87 T.
I have found a decent set of doors from an 84 cutlass. They are manual window doors. Mine are power.
1. Will they work?
2. How big of a pain in the arse will it be to swap all my door guts into these donor doors?
TIA
Joel
Not bad. You will have to drill out the rivets holding the power stuff in your current door. Then swap over to the new door and attach with small bolts. Use stainless since water will get in there eventually. You may have to knock out a plug in the front of the door to run your wiring through but it's not a bad job; just transplant one thing at a time, side by side, and you'll be fine.
