Door/window Outside Rubber Seal
PaulRV6
Does anyone know if this part is available through GM?
It is the outside rubber seal that sits on top of door and window rides against it.
It carries P/N 20674292 and 20674293.
Mine are all dry and cracked.
paul
Yes they are still available from GM. I just ordered mine yesterday and they came in today. The part numbers on www.gnttype.org are correct.
Eric, are the P/N you gave for the rubber seal on the outside of the window (not the felt one on the inside)? I got my P/N from a GM book that I have.
Good news though that they are still available. How much were they SpotMY6? Did you get the outside rubber seals?
paul
Eric listed the correct numbers. Outside belt moldings, black. Around $34 ea from http://www.partszoneonline.com/contactUs.html
Talk to Bill Sr. They don't rip ya on the shipping like some other places. I'd be interested if yours fit any better than mine. The one's I got seemed to have too much of a bend in them.
David
These are most likely chromed. The black ones are no longer available I'm told, so if it matters to you don't forget the paint.
They're black, not chrome. Still available as of yesterday. In fact, GM must still be having them produced. The date codes on mine show they are less than a year old.
David
Kirbans($100 a set) & Postons sell them also.
Sounds good, I'll trust you guys!
I just used Eric's numbers and David's description of the parts as black and ordered a set.
I bypassed calling and talking to Bill Sr. and just ordered online though. I hope the numbers were good, cause the description online just says S/STRP. Whatever that means.
Like Eric said, $34.12 each + tax in PA. Naturally I'm in PA. ;) The shipping worked out to be $2.43 for UPS ground. WOW!!
Since mine are not only dry and cracked but all but totally nonexistent, I am glad the information I had was wrong.
Thanks,
Jeff
I just picked mine up the other day from the dealership. I got a deal from a friend who is a manager there, so I got them for a little less than a normal customer
2 were $34 each
2 were $25 each
The pieces that go on the inside of the car on the upper door panel have a chrome strip on them. They are exactly like the factory original pieces.
2 were $34 each
2 were $25 each
It's the $34 ones that go on the outside, right?
I know the inner ones should have chrome, and the outer ones should be black.
