May 4, 2008 #1 B BandAid Keyboard Bully Joined Oct 4, 2004 Messages 3,964 was surfing and found this by mistake,,but thought of the community... Pioneer USA - Premier
May 4, 2008 #3 B BandAid Keyboard Bully Joined Oct 4, 2004 Messages 3,964 thought someone was looking for a dub..
May 8, 2008 #4 B Boston GN Well-Known Member Joined May 24, 2001 Messages 1,987 Saw that in Crutchfield Mag the other day. That thng is pretty slick. Wish I could fit a 2din
May 12, 2008 #6 S supsix New Member Joined Dec 15, 2007 Messages 7 Wouldn't it be a tight fit?I wanted to try a kenwood dvd double din pretty bad.I thought it might go if the black bracket around the ac/heater switch was removed.You guys would probably know more but like I said,I was sure hoping.Thanks
May 12, 2008 #7 G GNTurbo6 Asian guy in redneck car Joined Aug 20, 2006 Messages 425 I believe I've seen someone fit a double din with a little bit of modification work on the factory brackets.
May 12, 2008 #8 L leprcon I love burnouts Joined Dec 11, 2005 Messages 279 it can be done takes like 5 min no real permanent damage, just remake stock radio trim if u want it to look stock use black lexan
May 12, 2008 #9 S supsix New Member Joined Dec 15, 2007 Messages 7 Thanks,it looks good.I'll at least try it.
May 14, 2008 #10 D diomedes Member Joined Mar 29, 2007 Messages 168 give me the steps Im Interested in how you do it??? leprcon said: it can be done takes like 5 min no real permanent damage, just remake stock radio trim if u want it to look stock use black lexan Click to expand...
Oct 5, 2013 #12 T turbobob924 Member Joined May 28, 2001 Messages 967 the new Pioneer double din DVD receivers with pandora dn iphone apps makes this very appealing.
