Double look
google the numbers on the fuel injectors to find out what their flow rate is. Once you find out what the flow rate of your injectors are, then get a chip that for sure matches them. Chips are cheap. I wouldn't take a chance on running an unknown chip when for $85 you could get a TurboTweak chip that will run safely and reliably.
If the injectors are old, or of unknown age, there's no better time than now to replace them along with the chip. They won't get any cheaper.
