BetMinesFaster
Turbo LSX Trader
- Aug 7, 2007
So the double pumper wiring was a mess on my car when I purchased it, as was the rest of the wiring, I stripped all of the wiring out that was not original. Now I need to rewire the doublepumper....So my thought is this to make it clean, safe and simple. Order another hotwire kit from caspers, modify the wiring to attach to the doublepumper, use the + wire from the factory pump to switched terminal on the relay then use the pressure switch under the hood to complete the relay ground to turn the pump on at 10psi. Any thoughts on this? That should be safe and simple, as well as a good clean install? Thanks, Ryan
