i'm tearing down for a roller cam (full throttle) install.  the motor only has about 5K on it.  i just got the timing cover and found a new double roller timing chain and a new tensioner.  i thought you weren't supposed to use a tensioner with a double roller chain?
so what should i do? reuse the chain and tensioner or buy a new set and ditch the tensioner?
if i should replace them, how do i measure for the size chain?
