Nov 28, 2003 #1 R rb84gn New Member Joined Jun 24, 2003 Messages 119 How good are the two peice downpipe if you get them welded also does it give you false knock if its touching anything.
Nov 29, 2003 #2 S sam87 old but still runnin Joined May 25, 2001 Messages 174 Works fine if it doesn't touch anything. Adjust it on the car before welding to ensure the fit is correct. Sure can cause a knock sensor reading if it makes contact.
