DP bolt Size
Kevin Turch
Senior Member
Anyone know the thread size of the DP bolts?
I needto get some new ones and not sure of the thread size
TIA
Kevin
Do you mean the bolts to hold the down pipe to the turbo?? If so they are M8x1.25. I think...
I went to home Depot and just sat in the bolt section until I found them.
On a THDP the above post is correct, prolly around 25 or 30mm in length X 4. The stock DP uses 2 only and I believe they are 10mm X 1.5 pitch thread.
Jim
Socket caps work much better for the THDP as well, I had used hex heads for a while and they were a pain.
Thats why im getting new ones :), mine are getting kind of crappy. With the socket head ones, is it easy to get a wrench in there?
The socket heads are the ones Terry supplies with his DP.They use the Allen key style drive.Very easy to get in.
If you are trying to use a 3" downpipe, the hex head bolts will likely contact the side of the downpipe. You'll probably need the allen head style.
Hex heads fit, but you'll be a while getting them in due to constrained positions of the wrench, and a thin wall socket won't fit. :)
