J Jimmy88 New Member Joined Aug 2, 2003 Nov 30, 2003 #1 What are you guys using for a drive shaft on a TH-400 swap? And where can I locate one of these. Thanks
F fast eddie Senior Member Joined Jul 24, 2002 Dec 3, 2003 #2 If the trans is going in a GN all you need is a t-400 yoke and the original Gn drive shaft,also you will need a spicer cobination u-joint ,spicer also makes the yoke. Ed
