Driver bucket seat track & shifter parts
rtanner68
Looking for a driver bucket seat track- manual.
Doing a split bench to bucket conversion, only I realize that the split bench track is a bit different than the bucket track. The bucket track turns outward at its mounting bosses- to make up for the inch to two inch decrease in mount location on the seat itself from the bench.
Also ned parts for GN floor shifter- I need the return spring that keeps the metal gear detent at "up" pressure- or else the shifter can freely flow through the gears. Its under the shifter lever and connects to the metal "u" bracket that keeps both the metal detent and the plastic shift pusher at pressure.
Lastly, I need the shifter mounting bracket that bolts to the floor and to the shifter. Thanks-
RT
