Driver side window loose?
turboaddict2
I was cruising on the highway today and noticed when I close the driver side window, the top corner of the window near the a-pillar ends up outside of the blow out clip. Also I can move the window side to side when its a quarter of the way open. window closes fine when not going at high speeds though. Is there an adjustment on the window to not make it wiggle?
You can adjust it all. Adjust window to make it go up a little tighter to the top. There's two stops. Just loosen the bolt that secures the stops and move them up slightly to allow the window to go up a little more. Adjustment is a trial and error deal.
It sounds like the window might need a little more inward tilt. If it's catching on the outside of the guide clip but rolls up and seals fine when sitting still or at low speeds it's being sucked out, the height should be OK, just needs more tilt
There is a guide at the back top of the door (looks like a spike)that guides/secures the window in place when rolled all the way up...it can also tilt the window in and out. Be careful not to adjust it to tight, it'll break the guide on the window.
When at speed, if you crack the OTHER window, it should roll up fine.
Johns right, the window adjust in EVERY direction.
When you take off your door panels, you'll be able to see them. They are secured by a 10mm bolt and a tab sticking out of a slot you can see.
