Driveshaft yoke upgrade
Cme2fly
WH1 driver
Looking to upgrade my driveshaft yoke to a 1350. Any suggests? After looking at Summit's website it seems that the length of the yokes very depending on manufacture. What length should I look for? Trans is a 2004r. TIA
are you also upgrading the rear yoke to a 1350?
if not, then don't bother. get a good driveshaft loop and let the ujoint be the weak link i nthe driveline instead of the rear end or trans.
You also need to upgrade the ends on the shaft to accept the 1350 joint or you'll have to use an adapter/conversion joint. You may want to get a new shaft built.
My OE yoke is worn out so, I thinking an upgrade is in order. Don't really want to add new ends to my shaft. Is a ductile iron 1310 a good alternative for a mid to low 10 Buick?
You can buy an aftermarket 350 turbo yoke and put on your driveshaft with the stock size u joint. I have been told by my local driveline shop not to run a conversion u joint. They are weaker than the 1310 joint you have now. I ran many mid nine second passes with stock size u joints with a trans brake.
Maybe I missed it, where does it say he has a 1310 joint?
On a mid to low 10 buick I wouldn't run a 1310, either stock (3R if I recall correctly) or 1350.
Have you had the DS out lately?? Reason I ask is the stock sized U-joints don't scare me at all, but if you are twisting the yoke that becomes a pain in the ass. If you aren't hitting the driveline hard enough to twist the splines then you aren't going to be hurting the u-joints (assuming we aren't talking about a high mileage stock u-joint).
I have had the driveshaft balanced about a year ago. I broke another transmission and after inspecting the stock yoke which ( I assume is a 3r) the yoke is worn so I am going to replace it. I ordered some Spicer 5-795X joints. So, my question is which aftermarket yoke should I use that accepts 3r joints?
If you find a aftermarket yoke that works with a stock 3R u-joint PLEASE post it up. I looked for one and couldn't find it anywhere, I personally ended up going to a 1350 Yoke with a 1350-3R conversion U-joint. Not what I wanted to do, but I didn't have the money to build a whole 1350 driveshaft. At least now I have a 1350 yoke for when the time comes and I get a 1350 DS made.
1310 is the stock size u-joint. summit or jeg's sell strange, hughes, moser or whatever brand 350 turbo yoke you want in a 1310 or stock gn size u-joint.
Not so much...A 1310 U-joint has the clips on the outside and is smaller than a 3R U-joint which has caps on the inside...Our stock U-joints are 3R.
I ended up ordering an aftermarket oe style 3R yoke. If I break it this time I will upgrade to a 1350 shaft, pinion, and yoke. Thanks for the help.
Dude where did you find it?? I couldn't find one about a year ago for mine.
Damn it's way cheaper than the one I got too...Let us know how it holds up, hope it works good for ya.
Ebay is running some type of promotion where you get 15% off of items listed on Ebay motors so, I picked it up pretty cheap. I'll keep you posted on how it holds up.
