A lot of guys say to use a shorter spring , and not use a drop spindle to lower thier cars, .This is true if you can only use one or the other. A shorter spring will place both A-arms closer to parrellel to the ground , this would lessen the outward movement of both arms while hard cornering or a big bump. With that said , A drop spindle can be made to work well by using an upper a-arm that has adj. mounting, uses a tall, bolt on ball joint, and installing a spacer of the right thickness between the tall joint and the a-arm bj mount, This would place the upper arm closer to straight out and leave the lower arm with some outward movement as it travels up, The upper arm would not move out as much as the lower one.
There are alot of ways to set-up a suspension ,ie, shorter springs, taller B-spindles , taller upper ball joints, drop spindles , useing some of the these in combination . Anyway my point is that Drop Spindles can be made to work very well.
JEFF
