Stock Car Parts... Dry Sump 4 Stage Pump
Keep in mind the only difference with these pumps is that you only get a single stage for pressure, the rest of the pump are suction stages.
I have a typical setup that came from a running Busch Series S2 OnCenter V6 that includes the mounting bracket, 28 tooth pulley, 6 fittings (you will need 2 additional fittings).
New is $900 plus and I need $300 for this one (this pump is in very nice condition).
Pump turns with no problems and the only reason I'm not using it;
I decided to go with Mr. Duttweilers Front Cover Setup.
If I had it to do all over again, I would go with the Dry Sump Setup.
It is straight forward with plumbing being the only problem.
Thanks,
Gary
