Mar 9, 2014 #1 B BOP4ever Member Joined Jul 6, 2007 Messages 892 Are these comparable to the HR bar for mild street strip cars to keep things from twisting ?
Mar 10, 2014 #2 scot w. GNSperformance.com Joined Feb 19, 2005 Messages 8,810 BOP4ever said: Are these comparable to the HR bar for mild street strip cars to keep things from twisting ? Click to expand... They mount the same way and work the same way, to the chassis and they both have "Rate" adjustments...
Mar 10, 2014 #3 B BOP4ever Member Joined Jul 6, 2007 Messages 892 So if I use the bar can I skip airbags ? Do I need new lower arms with the bar or is stock ok?
Mar 11, 2014 #4 scot w. GNSperformance.com Joined Feb 19, 2005 Messages 8,810 BOP4ever said: So if I use the bar can I skip airbags ? Do I need new lower arms with the bar or is stock ok? Click to expand... Air bags are intended to quickly add rate to one side or both.......The sway bar has adjustable rate settings on the bar it's self but it's a different "rate" than what the air bags do...
Mar 11, 2014 #5 Pronto No amount of evidence will ever persuade an idiot. Joined Dec 9, 2002 Messages 16,746 The stock control arms are surprisingly weak. Makes no sense to increase the sway bar strength and use wet noodles for control arms.
Mar 15, 2014 #6 B BOP4ever Member Joined Jul 6, 2007 Messages 892 Ordered a hell wig after reading the positive reviews on here seemed like a good deal at 200 bucks shipped. Thanks Posted from the TurboBuick.Com mobile app
Mar 15, 2014 #7 Q qws2000 Active Member Joined Jan 12, 2012 Messages 504 I have the DSE rear Bar and it is awesome with Double adjust coil over uppr /lower from Ridetech..... What a big differance
Apr 15, 2014 #8 IrvJr Well-Known Member Joined May 28, 2001 Messages 2,547 I have the DSE and absolutely love it.
Apr 23, 2014 #9 K kels87gn Member Joined May 16, 2012 Messages 228 Could you post pictures once you have it installed?
