Dual BB Turbo (No Water Lines)!
Hartline Perf.
Looking at getting a Dual Ball Bearing Turbo, but don't want the hassel of running Water Cooling Lines?!
Precision Turbo has Now released AIR COOLED BB Turbos!!:cool:
Here are the Current Sizes Available.....
5457BB
5557BB
5757BB
5857BB
5865BB
5957BB
5965BB
6057BB
6157BB
6165BB
6265BB
6365BB
6765BB
MORE SIZES WILL BE RELEASED AT A LATER DATE.
Here is some more information about these Turbos.....
These units feature an air-cooled, ball bearing center housing rotating assembly. Dual, angular contact ceramic ball bearings are utilized for maximum durability and an increased thrust load. These units require the use of a 1/8” NPT male fitting on the oil feed side, which can be purchased separately. At this time, PTE does not feel it is necessary to use an external oil feed restrictor fitting. At the minimum, PTE recommends the use of a -10AN oil drain flange/line. This flange can be purchased separately. Water cooling is not required on these units.
Give us a call and order yours today. 321-722-1563
Holly Hartline
Hartline Performance
