marleyskater420
still needs to learn
- Aug 14, 2004
WORK Turbo and RPS are PROUD to offer a BRAND NEW Turbo for those looking to maximize their 3-bolt turbo setup! This turbo uses a .85 AR Buick 3 Bolt turbine housing, and a 4" inlet, 3" outlet Compressor housing.
To quote Reed Partridge, the owner of WORK Turbochargers, he has this to say about this turbo:
"This has our 72mm compressor wheel, and our 9 bladed 76x68mm turbine wheel. This exhaust wheel is produced in Germany and is a full Inconel piece, the compressor wheel, backplate and housing are all made right here in the states. It still uses a special Garrett ball bearing center housing, made in Japan or their Mexico facility. The 9 bladed option makes it ideal for peak flow, low mass and optimal performance in a smaller volute turbine housing, like the 3 bolt Buick.
(This Turbo Includes) Full ball bearing, water cooled and every possible update to make it 100% bad ass. "
This turbo has a price of $2,250 plus shipping, and this price INCLUDES the required water lines and oil feed fitting, which are an almost $200 value.
This turbo is a DIRECT competitor of the Precision Gen 2 CEA 6870 turbo, except this turbo costs a few hundred dollars less.
If you have any questions about this turbo, please call 707 362 6030 or email us at 1987GN@gmail.com
Thank you!
Tyler
www.boostedrps.com
THE NEW TURBOS WILL NOT HAVE THE SANDING/GRIDING MARKS ON THE COMPRESSOR HOUSING THAT THE TURBO HOUSING BELOW HAS.
![](/proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fv2%2F1280x1024q90%2F921%2FNV9mZI.jpg&hash=0e71b76b1f05a5830071da92f210fc7f)
![](/proxy.php?image=https%3A%2F%2Fimagizer.imageshack.com%2Fv2%2F1280x1024q90%2F923%2F2BXJZp.jpg&hash=0ba8296f627aa070938d1e27f2f691fe)
Thank you!
Tyler
www.boostedrps.com
