dual fan unit
Velon
I'm going to a front mount intercooler, I purchased ramchargers direct replacement dual fan unit, but it appears way too big. Anybody know of this problem. thanks
Andy
what direct replacement dual fan did you buy ,
the valeo is far from a direct replacement for a buick since its originally for a dodge, but it fits extremely well with a little modification (remove the mounting ears and if you want to install it at the bottom you may find you need to grind off a little of the fan arm to clear the PS box)
dual fans
thank you for the info squid4life, I'm going to give it a try.thanks again.
Andy
thanks for the reply pacecarta. I bought the one that ramchargers had with the correct wiring harness. So I should clip off the ears on it and it should fit between the ears on the radiator huh? thanks
Andy
