dual nozzle install
PaCemkr86
WFO Racing
Staff member
is it ok to stagger the nozzles or is there a reason why most people put them facing each other???
Doesnt make a difference. Its like asking a drunk if he prefers a clean glass :D
ok i found this pic... is this still ok?
Nope, bottom nozzle places it under the height of the liquid.. can you say SIPHONING :redface:
9 and 3 o'clock. 6 iches from TB.
i staggered mine slightly , i went with center of the up pipe (9:00 and 3:00) due to the higher than normal uppipe location from the MPE 70mm plenum, otherwise i like 10 oclock on the stock setup
would have moved them a little further back but I had the hose clamp connector to deal with from previously having the maf there .
Hth
How long should a typical installation take? How difficult is it to dial-in? Do you need to take it to a dyno tuner to dial-in?
Tuning takes some a lifetime :D Cuase we're always making changes.
I think your question is off topic for this thread. To install a couple nozzles.. an hour?? To install a kit.. ~3-4 hours for some. 16 hours for others. I can do an install in 2-3 hours typically. Some cars can be a bear.. like rotten hoses, oil in throttle body, oil in IC, etc..
Tuning an alky kit in.. totally different subject.. you have a lot of reading to do.
Start here
http://www.turbobuick.com/forums/alcohol-nitrous-propane-tech/147348-tuning-alkycontrol-kit.html
Do you know of anybody in Southern California who carries your kits and does the installation as well?
Sod at Hye-Tech has done the sale/install. La Puente CA 626-855-1154
